Default Data Path and LVCompare
I am running into a problem which superficially seesm similar to:
http://forums.ni.com/t5/LabVIEW/Custom-default-data-directory-path-reverts-to-Labview-default/m-p/36...
I have relocated my Default Data directory of my LV 2012 SP1 installation so that it is on a SSD (mostly because of my compiled cache).
Now I realise that LVCompare doesn't seem to work.  Can it be that it's hard-wired to the default directory?  I do a lot of comparisons when committing my code and not having LVCompare working is hurting me. Funnily enough when I do a LVCompare from within the LV IDE (via Invoke node) it works fine but the standalone EXE doesn't work.
Is there an INI setting to fix this?  My LVCompare.exe doesn't seem to HAVE an INI file at the moment.....
Message 1 of 10
(4,038 Views)
Hmm, I don't actually have permission to write to this folder so maybe creating a shortcut with command-line commands (if possible) would be a possible solution?
Message 2 of 10
(4,033 Views)
Hi Intaris,
try to follow these instrucions. You can start LVCompare.exe from the CMD prompt with the absolut paths of the VIs you want to compare. Hope that helps.
annav
Anna Vogl
Certified LabVIEW Developer
Message 3 of 10
(3,991 Views)
That's not the problem, LVCompare DOES get called, it just returns an error.
It returns:
An error occurred while running LVCompare
NI_LVConfig.lvlid:Load.vi<ERR>
D:\path\LVCompare.ini
<b> Complete call chain </b>
  NI_LVConfig.lvlib:Load.vi
  NI_LVConfig.lvlib:Open Config Data (compatibility).vi
  LVCompare.vi
And the D:\path is the NEW Temp Path I have defined within my LV options.  I also forgot to mention earlier that I re-mapped TEMP and Default Data to my D Drive which is an SSD.  The mentioned LVCompare.ini does not exist at that address but rather at the OLD default address in my user folder.  So apparently LVCompare tries to load an INI file at the new address, but something else has actually written the file to the default address.  Naturally enough, this doesn't go too well.
Message 4 of 10
(3,979 Views)
I'm sorry, I missunderstood.
Where do you find the ini file? The LabVIEW installation itself is still on C:? I will see what I can find out.
Anna Vogl
Message 5 of 10
(3,961 Views)
The labVIEW installation is on C: in the default directory.
LVCompare is at the default location.
The LabVIEW paths TEMP and DEFAULT DATA DIRECTORY are non-default on 😧
When I run LVCompare from the command line, it writes an ini file to the default TEMP directory on C: whereas it then tries to read it under the new directory on D:.
Message 6 of 10
(3,948 Views)
HI,
I did some research yesterday and didn't find anything that would help. I will try to contact my collegues in the US. I hope they can help us.
I could see the same behaviour with my LV 2015.
Can you, for now, change the Temp path back to it's original location?
Best,
annav
Anna Vogl
Message 7 of 10
(3,887 Views)
I normally use LVCompare programatically so the problem has limited scope.  I have code which iterates recursively through a given directory and runs LVCompare programatically on the VI and it's corresponding repository counterpart.  This way I can sort out those which have no "real" changes - mainly due to RT deploys - and revert them.
I'll just avoid calling it directly from Tortoise SVN for the time being.
Message 8 of 10
(3,873 Views)
My collegue in the US told me that copying the INI file from the default Temp folder to the new location would be a workaround for the issue.
I will file a corrective action request so that this problem will hopefully be solved for the following versions of LabVIEW.
Good luck with your project.
annav
Anna Vogl
Message 9 of 10
(3,840 Views)
What was the CAR# and has it been resolved?
Message 10 of 10
(794 Views)
