Deleting plot definitions from chart / graph legend
I am trying to remove plots definitions from a chart, but I cannot seem to find the way to do it. While I can add new plots by simply expanding the legend or clicking on the grey box, there seems to be no way to get rid of them, and this becomes especially annoying when you are using a scrollbar and there is a 'graveyard' of unused plots at the bottom. Unfortunately, changing the number of legend rows will only change the size of the legend but not the number of plots, so that doesn't quite do the trick when using a scrollbar.
I have only been able to find this
http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/pl_number/
which does not actually set the number of plots, but the legend display size
Does anybody know a way to get rid of them? Or some sort of workaround?
Thank you in advance
(4,464 Views)
Accepted by topic author Gongniu
In addition to changing the size of the plot legend, you can also adjust the minimum number of plots to display. Make sure this isn't too high.
Assuming that you've fixed that to a low enough value (e.g. 4) you need to wire data with fewer plots to the waveform chart. I wired a constant 0 to the input and ran the VI and it immediately reduced the size of the legend (and the number of visible plots) to the value I specified for the minimum and legend size (4).
GCentral
(4,458 Views)
Thanks cbutcher!
Setting LegPlotMin and LegNumRows in the property node deleted the extra plots. The behavior doesn't seem very intuitive.
Cheers,
Gongniu
(4,430 Views)
(Also have a look at this idea.)
(4,413 Views)
