Deployment Error
Could someone explain these errors to me?
System was working fine earlier,now I have nothing in my distributed system manager.
I had various files under local host earlier. Pulling my hair out here,
(2,189 Views)
Accepted by Newton1878
Hi Newton1878,
This looks like the same error as described here. Could you check the possible solutions for this?
If this is not the cause of the problem, could you give us a bit more information about how your system is set up and any changes that could have caused a corruption in the Shared Variable Engine?
Kind Regards,
 Riley Ilieva
Applications Engineer
(2,145 Views)
