Disabling the Tools Palette at run time
I'd like to utilize <shift> + <right mouse> on a control through an event structure at run time, but this is the shortcut that brings up the tools palette.  Is there a way to suppress the shortcut so that the tools palette doesn't come up at run time?  I am already using the "Run-time shortcut menu/Disable" setting on the control, as well as the generic "Front Panel Window: Allow Run-time popup=F" property.
(2,518 Views)
What action are you wanting to impose after the event condition is met? I'm betting in the Event Structure that the Click/Shift can be suppressed using the Event Filter Nodes on the right hand side of the Event Structure.
Logan H
Applications Engineer
(2,488 Views)
I am using the MouseDown and MouseMove events to teleoperate a robotic system. I apply 4 different behaviors, using left/right MouseMove with and without the "Shift."  Using the filter node, I found that the tools palette pops up before the filter event is generated, so I cannot dispose of the palette that way.  As a workaround, I am using "Ctl" instead of "Shift" for the mouse events.  However, the system utilizes an analogous control setup using the keyboard, and I find that I am forced to use "Shift" in that case because holding down "CTL"+ arrow keys locks things up.  I would like to use the same Platform Modifier in both cases, for consistency.
(2,450 Views)
Accepted by Womack
Build your application into an .exe and you don't get the tools palette on a right click.
(2,433 Views)
