Discover IP Address In String
I am faced with an issue of finding the IP address in a string containing other string like items... such as letters and numbers and... (ok, I'm just messing around).  Anyways, the string could look like the following  "10.0.0.1 stuff, stuff, stuff" or "stuff, stuff, stuff, 10.0.0.1 stuff, stuff."  The bright side is that periods/dot is only used for IP addresses while comma is used for everything else.  So I was thinking... well ok, I could just use a while loop and match pattern to solve this one. But then I thought.... "that's so primitive.  Surely, there's a better way to do this."   Sooooooo, is there a better way to do this?  I'm using LabVIEW 2011 just an fyi.
Message 1 of 9
(5,757 Views)
What's wrong with primitive?  Sounds like a good way to solve it.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 2 of 9
(5,752 Views)
Accepted by topic author DailyDose
Use "Match Regular Expression" with one of the expressions listed here: https://www.safaribooksonline.com/library/view/regular-expressions-cookbook/9780596802837/ch07s16.ht...
EDIT: more specifically, you want to use one of the expressions for matching an IP address from within a larger body of text, of course.
Message 3 of 9
(5,735 Views)
Hey man, we all want to move along just a little quicker (poor wheel reference)
Seems like the following match would be ideal to search for,
^([0-9]{1,3})\.([0-9]{1,3})\.([0-9]{1,3})\.([0-9]{1,3})$
 However, it would appear this syntax does not agree with LabVIEW.  You sure about this?
Message 4 of 9
(5,725 Views)
As I noted too late in my edit, you want to use the version for finding an IP address in a larger block of text, rather than the first version on that page. the ^ and $ are beginning- and end-of-line patterns, and you're not looking for an IP address on a line by itself.
Other than that, is there some way in which that syntax doesn't agree with LabVIEW? Works for me once I remove the ^ and $.
Message 5 of 9
(5,719 Views)
Ok, I hate being Mr. Spoonfed, but might you be willing to post a jpg of your VI so that I may compare to mine own.  I'm using match pattern but receiving no matches.  Does your text contain more than just IP addresses?
Message 6 of 9
(5,693 Views)
On second thought, here's mine
Message 7 of 9
(5,672 Views)
The function you need to use is Match Regular Expression, not Match Pattern.
Message 8 of 9
(5,662 Views)
Yep, thank you sir!
Message 9 of 9
(5,635 Views)
