Display Temperature and Time on a graph in LabView
I want a LabView program who calculates the temperature at which a  flow of water is heated with the help of a resistance. The program includes:
  • entering the necessary data (flow of water and power of resistance) through elements on the front panel or by reading them from a file
  • the possibility of changing the flow of water and the power of resistance values from the front panel and to display the results on a graph Temperature=f(time)
  • the possibility to save the dates in a text file
Thank you! 💛
Message 1 of 8
(1,277 Views)
Hi daughter,
@labviewsdaughter wrote:
I want a LabView program …
Simple answer: then you need to create such a program!
The generic answer for your rather generic question is:
  • we will not do your homework
  • we will be happy to help you with your code - as soon as you attach your code!
Message 2 of 8
(1,268 Views)
  • entering the necessary data (flow of water and Power of resistance) through elements on the front panel or by reading them from a file
  • the possibility of changing the flow of water and the Power of resistance values from the front panel and to display the results on a graph Temperature=f(time)
Thank you! 💛
Message 3 of 8
(1,263 Views)
Hi daughter,
no need to start a new thread for the very same question, especially when you already got an answer!
Message 4 of 8
(1,260 Views)
Message 5 of 8
(1,203 Views)
Hello daughter,
could you please downconvert your VI to LV2019 (File->Save for previous) and attach again?
Message 6 of 8
(1,196 Views)
19 VI and thank you again!
Message 7 of 8
(1,187 Views)
Hi daughter,
All this is already found in your VI, so what is the actual question/problem?
Recommendations:
  • NEVER delete the label from frontpanel elements! You may hide the label on the frontpanel, but should not do so in the block diagram!
  • When converting from °C to K you usually don't add "283". LabVIEW may do this for you by using two ConvertUnit functions…
  • You should learn to create plots for your XY graph. There is a nice example VI in the example finder, which explains the differences for chart and graphs!
Message 8 of 8
(1,182 Views)
