11-07-2022 03:03 AM
I'm trying to display 3 variables built with a cluster (time & numeric format).
When I format de X-axis as date, the value points doesn't correspond with the day in the plot.
Any idea what is happening?
The marker spacing of the X-axis seems to be 5, however, when it arrives to 28/10, the next mark is 01/11(!) instead of 02/11.
I'm using LabVIEW 2020 on Win10.
11-07-2022 05:21 AM
check this please
11-07-2022 10:07 AM
Using LabVIEW on another computer, it happens the same issue.
11-07-2022 10:13 AM
What if you show hours and minutes too? Are you sure that the HH:MM part of the date is null? If not, the actual shift may be shorter than 5 days.
11-07-2022 11:39 AM
When I show the time option in the X-axis, it appears 23:00:00(!) instead 00:00:00. So, the solution is to fix the time in the X-axis
