Displaying waveform from oscilloscope in Labview
Hi all,
I am trying to display a waveform from an Oscilloscope I have connected up to my PC. All has been connected correctly which has been checked in NI MAX. I now need to write a program to display the waveform of the Oscilloscope in the program. Once displayed the program needs to be capable of measuring the peaks of the waves.
Some details:
- Model: TDS 3034C
- Connection is serial.
Thank you for any help,
Hraym
(595 Views)
Hi hraym,
Some details:
- Model: TDS 3034C
  1. Look for a LabVIEW driver in the InstrumentDriverNetwork (www.ni.com/idnet) for your scope.
    Use that driver to communicate with your scope.
    When there is no (suitable) driver: read the programming manual of your scope and write your own driver.
  2. Now implement your "peak detection" for the waveforms read from the scope.
    (LabVIEW already has a PeakDetection function, maybe you can use it!?)
(565 Views)
Accepted by hraym2004
There is a driver and example available at Tektronix TDS3034C 300 MHz Digital Phosphor Oscil
Download and extract it to <LabVIEW>\instr.lib
(564 Views)
