Distinguishing Main VI and subVI
Hi
I have a very basic question; how do you tell the main VI from subVIs? I have a project file that has numerous classes, folders and other VI and controls. The overwhelming high number makes it difficult for me as a beginner to understand what is what and how are they related. Any help is appreciated.
/Hastie
(2,915 Views)
Accepted by Hastak
Hi Hastie,
simple: a subVI is called from a mainVI…
- It would help to give those VIs better names! I often name the main VI of a project using a scheme like "project_Main.vi"…
- It would help to sort the subVIs into (virtual) folders in your project tree.
- You can use the VI hierarchy view to see the relation between VIs.
- You can right-click a VI in the project tree and "Find callers" of that VI…
(2,913 Views)
Thanks for your reply Gerd, the "Find Callers" option really helped. When I look at the Vi Hierarchy of the "suspected" mainVI, there are many subVIs that that not included in the project folder. They mostly seem to be coming from the drivers used, is that normal? Shouldn't they also be in the project folder? If not how does the program know where to look for them?
Sorry for perhaps too obvious questions!
Best,
/Hasti
(2,899 Views)
Accepted by Hastak
Hi Hastie,
Yes, that's normal.
All VIs in user.lib, instr.lib and vi.lib usually don't belong into the project.
Did you notice the "Dependencies" sub-tree of the project?
(2,889 Views)
