Distorted 3D figures in LabView 2013
Hello everyone. I am new to the forum and have a problem with 3D images.
Figures appear incomplete or distorted. I have read that it can be a problem regarding OpenGL settings and the video card in that case I would like to help me set it up.
These are my Hardware features:
Core 2 Quad Processor
MB Asus P5Q3
4GB RAM
Video Card NVIDIA GF GT630 (with OpenGL and CUDA Support)
I tested this on two computers and always with the same results.
Please, I need URGENT !!!
Attached some pictures from the issue (examples of LabView: linear inverted pendulum, pendubot, F14 Tomcat Longitudinal Simulation)
(3,186 Views)
Accepted by topic author jecks_00
hmmm.... I think I've seen this before. Is your machine setup to use 'comma' as a decimal point? The import VRML file will not work well if that is the case.... LabVIEW has an option to ignore decimal point localization in Tools >> Options... >> Front panel: Use locallzed decimal point* . Uncheck and reinicialize LabVIEW.
Let us know if that helps,
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,129 Views)
Didn't work, more ideas?
(3,100 Views)
hmm.. that is strange.... it used to work.... Then, your option is just change the decimal in the OS from "comma" (,) to "period" (.).
I tried here on a French OS and I was able to read the file correctly...
(3,061 Views)
Hello again with good news...
I tried both changing the comma from LabView as the change from the OS and it worked.
Thank you very much for the help.
(3,026 Views)
