Do nothing in a double case structure
pincpanter escreveu:
You missed the point: in the selected condition you would not set the voltage at all. See the following image.
Just to clarify the situation, please read my answer above (you were probably typing yours when I've posted).
I understand the matter and I agree with that.
Mondoni
Message 11 of 14
(729 Views)
Joaoparm, indeed I was answering to the OP, however I agree that we could use a selection function. As thoult pointed out, however, this is less flexible.
Paolo
Message 12 of 14
(708 Views)
this looks troubling.....anyone knows why? surprised no one caught this.....
can you please post your vi so that we can understand the 'whole ' picture...
Message 13 of 14
(704 Views)
Thanks for your answers. As for the equal condition it´s not a problem at all, I put it there just for testing but I´m usually using a lower or equal to condition. This is how it works:
Two parameters, one measured M(t), one applied A(t). Depending on the values measured we change the applied one.
Ao is applied at the beginning until M reaches Mf, then we switch to -Ao until M reaches Mi, then we switch back to Ao until M reaches Mf, and this a certain number of times. My problem was that we reach Mi two times, at the beginning (in this case we need to keep applying Ao) and a second time (and here we need to switch back to Ao). I was thinking of putting something that indicates the sign of Ao, it would make the cases simpler, but then I thought maybe it would be even better if I just didn´t change A in the corresponding case.
I hope this clarifies it apok.
Message 14 of 14
(658 Views)
