07-08-2015 10:20 AM
I am soon going to implement an exe from 2013 onto a server of which network shared variables will be fed from a lab PC. Before I start down this road I want to be shure that when I compile the vi (that will be on the server) it will be in 64 bit. Having trouble finding the exact answer in literature.
07-08-2015 10:24 AM
07-08-2015 10:32 AM
Our IT person said it will only work if it is in 64 bit. Also it appears the version I am using is 32 (13.0f2). This is what defaulted when I open LV. Is there a way to default with 64? If so will all my vis simply re-compiel when opened in 64 bit version?
07-08-2015 10:36 AM - edited 07-08-2015 10:36 AM
The 64 bit versions of labview require their own install. I tried a while back to install a 64 bit version of LV, and the only version I could find is LV 2014 64 bit. It was surprisingly hard to find older 64 bit LV versions on the NI website.
Should be around somewhere though, I'd think.
EDIT: A word.
07-08-2015 10:40 AM
07-08-2015 10:42 AM
I am uncertain and I am asking for a more detailed explaination from our IT person. I beleive it is or maybe a restriction on the server.
07-08-2015 10:43 AM
Can you get clarification from IT about this statement? Is there a random policy in place? Are they worried about anything specific?
A 32bit LabVIEW applications works fine on a 64bit OS (but not vice versa).
07-08-2015 10:45 AM
I agree that it maybe an artificial restriction and I will get clarification.
07-08-2015 10:49 AM
The only downside to 32-bit Labview I've found (in my limited experience) is a memory restriction, which is common to any 32-bit program. Other than that, 32-bit LabVIEW is usually what is recommended.
07-08-2015 10:52 AM
I just recieved an explanation form IT;"They do not make a 32 bit version of 2012 Server".
