Does anyone know how to stack plots by group? I'm struggling. Read below to better understand what I mean (VI attached)
I know how to stack plots individually as shown below.
This below is what I would like to achieve but I just don't know how to go about achieving it. I want to group voltages in one chart and all the pressures on another chart. Both charts will be sharing the same x-axis (time).
(1,124 Views)
Accepted by topic author GRCK5000
Hi GRCK,
Use two charts…
(1,083 Views)
it is definetly easier to use two charts as Gerd suggested.
but, you may consider a mixed signals graph using two groups.
note, this is a graph not a chart, so you need to built a buffer inside the loop for each plot to mimic a chart.
furthermore, you have to manually drag and drop plots from one group to another.
also, scaling a mixed signal graph is tricky compared to the usual graph and charts
1# set-up your .vi like this
Spoiler
2# spawn a fresh mixed signal graph and connect it to the last bundle array node
Spoiler
3# run the .vi once
Spoiler
4# spawn group 1 by rightclick> add plot area
Spoiler
5# resize the mixed graph area height  via Properties>Apperance from 219 (default) to 482
Spoiler
6# drag and drop plot 0, 1 , 2 into group 1
Spoiler
(1,056 Views)
Thanks Gerdw! This will definitely work.
(1,024 Views)
Thanks Alex! Your strategy is amazing. Also I like how you are showing the steps to get this done. Awesome!!!
(1,022 Views)
