Dragging code into a structure in LV 2018
Hi, folks, do you know if there is any way to turn off the new wire-healing feature that affects dragging diagram code pieces into or out of a structure (loop, case, or sequence structure)?  Turn off via some setting or perhaps a line added to the LabVIEW.ini file?  I'm running LV 2018 SP1 f2 on Windows 10.  The feature is really annoying and time-wasting when dragging in a piece of code that does not have any tunnel attachment to the walls of the structure, and any wires in the piece of code that are in close proximity to elements get repositioned or completely rerouted.
Joe Czapski
Draper, Cambridge, Mass.
(2,127 Views)
Accepted by Station4
(2,120 Views)
