Dynamically Deploy Real-Time Startup Application
I am trying to dynamically deploy a .rtexe to cRIOs using WebDAV and the System Configuration Palletes.
Here is an example VI which shows my approach:
Will this work? Is there a way to trasnfer files using the System Configuration VIs that I'm overlooking?
(947 Views)
I couldn't find any information or example on how to use the Install Startup VI.
You can use Programmatically Enable/Disable RT Startup Application Using RealTime for LabVIEW to modify the INI token for Deploying a LabVIEW Real-Time Startup Executable Without the LabVIEW Development Environment.
(935 Views)
