Dynamically naming clusters for JSON
I am trying to create a JSON formatted output that dynamically changes the name of the JSON object based on the loop iteration.Dynamic JSON.png
Right now my output formatting is like this:
    "Variant":{
        "Letter":"VIL",
        "Number":9
    "Variant":{
        "Letter":"RVK",
        "Number":8
 But I want it to appear as this:
    "Loop Number 1":{
        "Letter":"VIL",
        "Number":1
    "Loop Number 2":{
        "Letter":"RVK",
        "Number":2
What am I doing wrong, and what do I need to do to make it right?
(2,681 Views)
Hi smurfinturf,
I doubt you really want to use variants and flatten to string.
Here's how I'd build that formatted string:
Hope it helps!
(2,647 Views)
Accepted by smurfinturf
Don't do that.  Use a JSON library; that way you will not get bugs due to edge-cases that you miss when using standard string formating instead of a library that follows the full JSON standard.
Here's an example using JSONtext:
(2,634 Views)
