Dynamically populate runtime menu for Multicolumn Listbox
I know that it's possible to create a custom Run-Time Shortcut Menu e.g. for a Multicolumn Listbox (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3TOCAY&l=en-US). However I would like to dynamically edit this during run-time. Is this possible? I did some googling but couldn't find an answer. I'm using LabVIEW 2018 32 bit version. Thanks in advance for any help.
(2,615 Views)
Accepted by AndyRR
Hi Andy,
there is a palette with menu functions: use it!
You should get the reference for your menu using the "Menu activation" event…
(2,608 Views)
Thanks a lot. I was looking for that Menu ref of a Muticolumn Listbox, but couldn't find it when i looked for it from the property node.
(2,581 Views)
