EXE UnicodeDecodeError
Hello:
     I was able to run the vi program on my development computer, but there was an error when I ran it as an exe. The error is as follows,
code 1671
error:<class'UnicodeDecodeError'>
'utf-8'codec can't decode byte 0xb1 in position 49:invalid start byte
Is there a configuration error? Any ideas on how to solve it?
    Looking forward to your reply!
(759 Views)
Hi and Hallo!
@hallo77 wrote:
I was able to run the vi program on my development computer, but there was an error when I ran it as an exe. The error is as follows, code 1671
Which VI?
(747 Views)
Error out from Python node.I have solved it, thank you for your reply.
(738 Views)
Hi Sir,
Could you please tell me how did you solve the problem? I am getting the same error (1671) from Python Node and I cannot solve it. Thank you so much.
(535 Views)
Error 1671:
<class 'UnicodeDecodeError'>
'utf-8' codec can't decode byte 0xe2 in position 67: invalid continuation byte
Does anyone have a solution?
(293 Views)
As I've just solved the same/similar error and this thread has no posted solution i thought I should share.
The error i recieved was:
"Python returned the following error: <class 'UnicodeDecodeError'>
'utf-8' codec can't decode byte 0xe4 in position 34: invalid continuation byte"
Check the path for and remove non-standard characters. In my case, I had an 'ä' present at position 34 in the path string to my .py-file. Changing the path to eliminate such characters made the error go away and the vi ran properly.
(58 Views)
