Ehternet Daq (9188) detection
I'm writing a piece of code that detects all the ethernet CompactDaqs connected to a PC. To do so, I use the "System Configuration" API.
I have muliple network cards in my PC and I'd like run the detection only on one specific NIC.
How can I do that?
peper
(2,662 Views)
You haven't posted any code (and if you do post, please attach the VI, not a picture of the Block Diagram, unless, of course, it is a LabVIEW Snippet), so I'm unsure how you are doing this.  Are you using Find Systems using cRIO as the Device Class?  Why do you need to specify which of your PC's NICs to use?
(2,642 Views)
