Elevator Simulation using LABVIEW AND SPEEDY 33?
Hello there, I am looking for a sample elevator stimulation by LABVIEW using SPEEDY-33. If anybody has a sample on how I should begin or how my elevator should look like please help. Thanks in advance.
(3,502 Views)
There is an example for notifiers that simulates an elevator.  Search "notifier" in the Example Finder.  That might get you started depending on what you want to do with the DSP hardware.
(3,482 Views)
the example that NIquist mentioned is "Multiple Notifiers - Elevator Example.vi". However it's hard to tell if this will satisfy tour needs for the simulation. However you didn't really specify what sort of simulation you are about to work on.
Jano
(3,469 Views)
I think that a good tutorial to start with the DSP module might be this one and probably continue with learn LabVIEW DSP in 3 hours.
Hope this will get you going.
General info on the DSP is here.
However if you have any question, feel free to ask  :smileywink:
Jano
(3,451 Views)
How to use input controls and output indicators of Speedy 33 module to realize an OR operation in Labview?
(3,186 Views)
Hi Biplap and welcome to the forums! 🙂
Have you taken a look to the links provided in the post above yours?
 They should provide the answer to your question, if I understood it right.
Jano
(3,114 Views)
