Error -1073807339 occurred at SOSL1260 Read Single
Hi, Im working with the Solartron1254 and use LV 7.1.
I try to take a single measurement with the driver sosl 1260.
I can send datas to solartron 1254 from LabVIEW
Localy i can take a measurement with the device but if i try to read the data with LabVIEW i get this error
Possible reason(s):
VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed.
This error occures at the Wait condition.vi.
On my device solartron 1254 i put F1=0 anfd F2=0  to Line feed.
i tried to expand the timeout but it was not working.
Can u help me?
(2,838 Views)
Are you sure that the 1254 is 100% compatible with the 1260 in terms of the command set? A timeout error could also occurr if the device doesn't understand the command that was sent by the PC.
Jochen Klier
National Instruments Germany
(2,834 Views)
Hello Jochen
 Yeah, the 1254 is not 100 % compatible to 1260 .The 1260 has some more options.
I found the mistake : It was the mask value was default 16 and this is wrong  if i change  it to 2 everything is ok.
Frank
(2,827 Views)
Hi Frank,
I am using solartron 1255 with the drivers of 1260. I have the same error even when changing the mask from 16 to 2.
Any help ?
Thanks !
(your post is very old, I have to repost the question for a new discussion)
(2,370 Views)
