08-29-2012 04:25 AM
I'm having a problem with sampling below a rate of 1k with the NI USB-4431.
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampClk.Rate
Requested Value: 100.000000
Valid Values Begin with: 1.0e3
Valid Values End with: 102.400000e3
Attached is my vi.
I've tried changing the wait but it makes no difference.
I'd really appreciate some help on this one please.
Thanks in advance,
AT12.
Solved! Go to Solution.
08-29-2012 05:19 AM - edited 08-29-2012 05:24 AM
Unable to open your vi. Can you post it in a lower version?
Also, what is the sample rate you tried? I assume you are using DAQmx timing function, or the DAQ Assistant.
As mentioned in the error message, the device accepts sample rates between 1K and 102.4K samples/sec.
Try with samples rates above 1k and things should work fine.
08-29-2012 05:31 AM - edited 08-29-2012 05:32 AM
Thanks for replying.
It does work fine higher than 1k but it is supposed to measure lower than this:
Four channels on the USB-4431 are TEDSanalog input channels that can sample from 1 S/s up to a full rate of 102.4 kS/s.
I need to measure at <1k S/s. I am using the DAAQ assistant.
I've Saved for Previous Version: 2009 - attached.
AT12
08-29-2012 05:36 AM
Hi
http://www.ni.com/pdf/products/us/cat_usb4431.pdf
As per the specificaitons in the above document, the sampling rate is from 1kS/s to 102.4kS/s
08-29-2012
05:53 AM
- last edited on
06-03-2024
10:41 PM
by
Content Cleaner
Oh right! I got my information from the overview here:
