Error 363513 Occurred when using smtp to send email
I'm trying to send email using SMTP. I getting the error of Error 363513 An error occurred while sending data on the network. How I can solve it? I've been struggling with this for quite a while.
LabVIEW 2016
STMP server: smtp.gmail.com
port: 25
Message 1 of 8
(7,039 Views)
Accepted by chiching
Hi chiching.  Do you know whether smtp.gmail.com will accept a connection on port 25?  Many email servers will not.
Do you know whether you can make an outgoing connection on port 25?  Many networks (and most residential ISPs) block outgoing connections on port 25.  Unfortunately the network I am currently on blocks outgoing port 25 connections, so I can't test smtp.gmail.com for you 😉
You can try using telnet to confirm that you can make a connection:
https://www.port25.com/how-to-check-an-smtp-connection-with-a-manual-telnet-session-2/
I wouldn't bother trying to make a connection with LabVIEW until you are able to send an email with telnet.
Hope that helps.
Matt
Message 2 of 8
(6,989 Views)
Hi Matthew,
Thanks for your reply. But I had tried for other port also having an error
Port 587: Error 363513, An error occurred while sending data on the network.
Port 465: Error 56, The network operation exceeded the user-specified or system time limit.
Message 3 of 8
(6,979 Views)
Hi chiching.  I would try telnet to connect to gmail on 587 following the sequence suggested in section 7.2 here:
https://gerardnico.com/wiki/email/smtp_telnet
If you get responses from the server that look like what is described, that will at least confirm you are connecting to the server.  You may have to set the TLS switch to actually send via gmail, I don't know.
Matt
Message 4 of 8
(6,959 Views)
Hi Matt,
My problem had been solved. I just set my port number to 589 and enable the TSL at the open handle VI.
Thanks for advice 🙂
Message 5 of 8
(6,957 Views)
Hi, I have the same problem with you and tried your solution, but it doesn't work. I use gmail server: smtp.gmail.com. With port number 587 I have 363513; with 589 and TSL true I have error 363500. Isn't it odd?
Message 6 of 8
(6,895 Views)
Hi Noriker,
Have you set the TLS to true?
Error 363513 is due you network connection problem. Try check your internet network.
Message 7 of 8
(6,881 Views)
Thank you so much for your reply. My problem is resolved. I have to turn TLS off to make it work. Must be different network settings? Many thanks.
Message 8 of 8
(6,873 Views)
