Error_389113 when increasing the number of inputs above 10 inputs
Hello everyone,
In order to get some informations from a Multisensor to a RS 485 through RTU-Modbus protocol I built the following program in LabView: Error_389113.png
I'm wondering why the following error −389113 occurs when I set the number of inputs above 10 inputs:
LabVIEW: (Hex 0xFFFA1007) A value contained in the query data field is invalid for the Modbus slave.
Function 4 +
The hardware I'm using:
I'm pretty sure that by duplicating the Read Input Registers VI the problem will be solved. However, I would like to understand the cause of the error.
Is there another way to call the informations than using the unbundle function ? maybe that could help ..
Thank you for your time 😊
best regards
ezzow
(1,257 Views)
Hi Ezzow
Did you to duplicating the Read Input Registers VI as you said?
After several searches, I came to that conclusion to consider on the error description, because there isn't more information about this error.
Regards)
(1,135 Views)
Hi l.hovs,
this is the only "possible" explanation I found:
source: Read Input Registers VI - NI
Yes, I solved the problem by duplicating the Read Input Registers VI.
best regards,
Yassine
(1,122 Views)
