06-29-2012 05:16 AM
Hola a todos,
estoy haciendo un proyecto de adquisición de datos con una tarjeta de adquisición de datos NI USB-6218. A la hora de adquirir los datos por las entradas analógicas utilizo el DAQ Assistant. Por ahora solo tengo dos señales analógicas conectadas y ya me da error. Os adjunto el error que me da y el .vi
Muchas gracias
06-29-2012 05:38 AM
Duplicate posts:-
http://forums.ni.com/t5/LabVIEW/Error-50103-en-NI-USB-6218/td-p/2049986
http://forums.ni.com/t5/LabVIEW/Error-50103-en-NI-USB-6218/td-p/2049984
06-29-2012 05:40 AM
yes, I'm sorry! But I don't know how erase it.
06-29-2012 05:41 AM
No problem you just continue in this thread.
06-30-2012 02:22 AM
Any suggestions??
Thanks!
06-30-2012 12:11 PM
Do a forum search for that error. It's been discussed probably hundreds of times by now. Try searching "50103".
05-29-2013 06:46 PM
all i find is people saying the error 50103 is already discussed, i have the same error. :c
05-29-2013 07:04 PM
05-29-2013 07:21 PM
i don't really get how to " combine all operations of the same type into the same task."
I get I have to use only one DAQassistant, but i don't know how to combine operations.
i.e. analog voltage sine waves from several outputs
