Error Code -2147023116
Does anyone have any ideas as to what might cause this error? <<A null reference pointer was passed to the stub.
 in Set Report Orientation.vi->Easy Text Report.vi->Generate Report Test.vi>> All I am using is the Easy Text Report.VI. I set the font to -1,-1,Times New Roman,12. The text is "Test". It is a standard report with portrait orientation. But the error code mentioned above gets generated when I run it. Any help would be greatly appreciated.
Message Edited by Mark70 on 09-17-2009 04:24 PM
(3,559 Views)
Accepted by topic author Mark70
Hi Mark,
Check this out.
Stephen Meserve
(3,537 Views)
Hi Stephen,
Thank you! Problem solved!
Let's go Islanders  :O)
(3,532 Views)
