Error on calc using formula node
I'm trying to do a calc using the formula node function
But i'm receving error all the time
I attached the VI with the formula node and the function
(403 Views)
Hi leandro,
Did you read the error description when trying to run your VI?
It says "Formula node: Missing right paranthesis" and it shows the part of your formula that goes wrong…
Instead of replicating this (extra-)large Excel formula with a formula node you should create a VI using plain LabVIEW functions. It also would help to replace the Excel coordinates (like D44) by real controls with useful labels!
(397 Views)
I found the error
I was trying to use the function to fetch the smallest value between two numbers, but it doesn't seem to support
I did the treatment outside and sent it into the formula with the value already treated
(357 Views)
Hi leandro,
As I wrote before: use plain LabVIEW functions, like the MinMax function…
(313 Views)
there is no 'and' function in labview formula node.
instead you might try to use '==' instead of '='
instead of 'and' try '&&'
(291 Views)
instead, you might try to  apply &&
To the OP: This is the perfect example of why you should try to use native LabVIEW primitives whenever possible.  Then there is no such thing as "syntax error".
Bill
CLD
(Mid-Level minion.)
(283 Views)
