Error while loading a LDF file
Context : i am loading the LDF using a test bench developed with Labview
Hardware Used: We are using a NIPXIe-8840 controller equipped with a PXIe-8510 card (NI-XNET interface) and LIN transceivers.
Error Description: While attempting to use a LIN Description File (LDF) with our setup, we encounter the following error when loading the file:
XNET Create Session (Conversion).vi:360014<APPEND>
<b>Complete call chain:</b>
     Hardware Model.lvlib:Hardware Model.lvclass:Configure LIN_3.vi
     Hardware Model.lvlib:Hardware Model.lvclass:Command.vi
     Hardware Model.lvlib:Command Msg.lvclass:Do.vi:3750001
     Actor Framework.lvlib:Actor.lvclass:Receive Message.vi:1040001
     Actor Framework.lvlib:Actor.lvclass:Actor Core.vi:5880001
     Hardware Model.lvlib:Hardware Model.lvclass:Actor Core.vi:5880001
     Actor Framework.lvlib:Actor.lvclass:Actor.vi:6640009
     Actor Framework.lvlib:Actor.lvclass:Actor.vi.ACBRProxyCaller.B2700003
The problem is not encountered in other tools (Vector equipment for example ) , we have also tried to generate the LDF using the tool but the problem is the same . can somebody help with this ?
The LDF is in attachements for syntax check .
Thank you.
(191 Views)
What is the error code?
What is your NI-XNET version?
Can you try to load the LDF file in NI-XNET Database Editor?
(160 Views)
