05-12-2016 04:05 AM
Hello there,
I am trying to make a simple voltage aquisition from a VISA connected Multimeter, feed the voltage reading (it's an array, but I feed only the frist element for this example, just until i manage to make it work) and use a MatLab script with a build-in function to plot this voltage. I get an error, and I have no idea why... Can anyone help?
P.S. I know I can do this simply and easily all by LabView, however due to the specific class project, I need to do interfacing between LabView and MatLab.
Thank you all in advance!!!
Bests,
G.
05-12-2016 08:14 AM
error:Founction definitions are not permitted.
I advises you look over founction which you has defined in Matlab script.
05-13-2016 01:42 AM
Hey everyone, managed to fix it by myself. Apparently need to sit down and read the documentation about the MathLab script more thoroughly. The function I used was not recognized, I guess... or the MatLab server was not able to execute it. However, I simply removed the function, and the script recognized atomatically the values for the 4 variables of interest, fed from the LabView code.
