Event case controlled by DAQ
Hello everyone,
I would like to control an event case with a digital input from the DAQ, so that when the input is at 1 the event case is carried out.
Can anyone help me?
Niccolò
Message 1 of 9
(1,274 Views)
Try using User Events to trigger an event whenever you receive the DAQ Input as 1.
Message 2 of 9
(1,268 Views)
thanks for the reply, hob just tried but it still doesn't work
Message 3 of 9
(1,262 Views)
Please do share the one which you tried, so that we can suggest you to get your problems resoved
Message 4 of 9
(1,253 Views)
What DAQ are you using and what is your goal?
Santhosh
Soliton Technologies
Message 5 of 9
(1,212 Views)
If you have a board that supports it, then you can use the Change Detection Event.
The Example finder has "Voltage (with Events) - Continuous Input.vi" for voltage input. For digital events, the structure is similar. Something like below to start
then wire the dynamic event registration into the Event Terminal, then make the corresponding event case
Message 6 of 9
(1,203 Views)
I tried to create a User Event and use it to activate the Event Case.
I'm at the beginning of Labview I don't know if it's right. 
Message 7 of 9
(1,163 Views)
I'm Using the DAQ NI 9375 and I would like to use my input as an event case activation
Message 8 of 9
(1,162 Views)
Hi nick,
You did it wrong…
I recommend to learn from the example VIs coming with LabVIEW, found in the example finder!
You need to enable user events in your event structure and you need to register the user event for that event structure!
(Why do you need an event to put some data into a queue? Why not do this in your DAQ loop?)
Message 9 of 9
(1,151 Views)
