Excel and .NET Problems
I know there is the RGT toolkit which I have and ActiveX which works, however, I would like to know if anyone has a solution to this problem using .NET. (@PhilipBrooks, .NET guru, if you are reading this.)
I am having problems determining the number of workbooks open with Excel and whether a particular file is open. Note the ActiveX versions posted here DO WORK, however I want to know why the .NET solutions do not work.
PNGs and VIs are attached.
Thanks for your help.
mcduff
Message 1 of 16
(4,953 Views)
Can you post the VIs for 2016 or earlier?
Message 2 of 16
(4,935 Views)
Thanks for looking into this.
mcduff
Message 3 of 16
(4,931 Views)
I've had no success yet, but based on this article I think you want the _Application property. The ApplicationClass is reserved for internal use. But when I select _Application it says no public constructors are available...
Message 4 of 16
(4,920 Views)
No, I think the ApplicationClass is correct.  However mcduff's code is creating a new instance of Excel, not grabbing the already opened instance.  If you put an ApplicationClass.Visible = True, you can see it flash onto the screen and then close.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 5 of 16
(4,904 Views)
This still does not work, but you can convert to a more specific type to the _Application Class, even when I use this class I can not get the count or find item. I think aputman is on the right track, we need a reference to the excel application that is running.
mcduff
Message 6 of 16
(4,889 Views)
Accepted by topic author mcduff
There is a way to do this in C# but I haven't figured out how to port this over to Labview .NET.
aputman
Message 7 of 16
(4,870 Views)
I think you are on the right track. Based on your previous comment, I too have been looking for the "GetObject" call in .net to try and get the current instance of excel. However, I cannot find it in any of the libraries that supposedly have it. I think if we can find that, then it may/should work.
Thanks again for looking.
Cheers,
mcduff
Message 8 of 16
(4,865 Views)
Thanks for your hints I think a found a solution to get the current instance of excel. Thanks for your help.
See snippet and VI.
mcduff
Message 9 of 16
(4,855 Views)
Awesome.  I will have to take a look at this on Monday because I couldn't figure out how to get the Marshal object.
aputman
Message 10 of 16
(4,847 Views)
