04-25-2018 08:54 AM
Hello there,
I am working on application where I need to make an excel file which has two columns, one for PASS UUTs and another for FAIL UUTs. For each result of test, i need to make an entry of unit's serial no. in respective columns.
I am using report generation tool-kit which has a function to get last row. However, it is returning value of 'bigger/longer' column. So, can i get last value for each particular column?
Attached is the excel file for reference.
Manan
04-25-2018 09:21 AM
