06-23-2014 01:29 PM
I have created a VI that accepts user input to collect, save, and open voltage waveforms from a DAQmx board. It is a while loop and a state machine with a lot of information in it so I understand that efficiency might be an issue. This lag only exists, however, on a Mac, whether it is compiled into an application or run through LabVIEW. The VI on my Windows 8 machine has no issue handling 1000 samples, but when I run it on my MacBook, asking for 10 samples creates approximately a 20 second lag between data aquisition and data display, and a 30 second lag when asking for 100 samples, etc. This is the case for my Mac desktop as well. Could this be an issue with the way a Mac handles this information/memory, and are there any quick fixes to reduce this lag? Thank you for your input!
06-23-2014 01:37 PM
It would be helpful if we could see a bit o' code.
Mike...
06-23-2014 02:20 PM
06-23-2014 03:24 PM
Thank you for your replies. I just noticed that the delay disappears when the sample length is over 0.05 seconds, so I'll just make that the minimum for now.
