Exe is Crashing after every test sequence
Dear All,
An Exe file is crashing every time after the test sequence is finished.
I have attached the photo of the pop up box occurring each time i run the exe file.
It would be helpful if somebody came across this issue and has a fix.
Thank you in advance for your reply.
Manju
(959 Views)
Hi Manju,
you "just" need to debug your executable.
None of us can help you with that part as we don't have the exe…
(941 Views)
Access violation in a 3rd party driver ... it sounds like you're not closing references in the correct order, e.g. you close a ref and then use it for some function.
Qestit Systems
Certified-LabVIEW-Developer
(937 Views)
Thank You.
I will look into it.
Best Regards,
Manju
(905 Views)
