Executable application
Whenever I launch the build application, the source VIs also launch simultaneously. Could you please advise me on how to launch the executable application without initiating the source VIs each time?
Thank you,
(391 Views)
Accepted by KS200
Thank you,
You should more specific, it is not clear what happened and expected.
Usually you have at least one startup VI in your build spec which will be executed at startup:
May be you calling some VIs dynamically and they loaded from source code folder? Or may be some VIs marked as Open Front Panel when loaded:
and Run when opened:
and running "unexpectable"?
Or do you need "GUI-less", like "console" application?
(356 Views)
Thank you for your response. I was able to fix the problem.
(286 Views)
Since this is a self-help forum, if you could describe the fix in a post (and mark it as the solution) that might help someone else who has the same problem.
Bill
CLD
(Mid-Level minion.)
(275 Views)
