Executing "bring to center" on a free cursor in a log XY graph brings the cursor to the top rim of the graph (instead of the center)
Dear support,
dear LV users,
selecting "bring to center" for a free cursor in a XY graph does not
bring the cursor into the center of the graph, but instead the command brings it to the
mean/average value. This is not an issue for a linear mapping
of the axis [due to the fact that the center of the axis is equal to
the middle/average value of the end points on the axis]. But when
mapping of the axis is logarithmic, the cursor ends up on the top of
the screen. That is because the average value of the end points
(min(y_axis)+max(y_axis))/2) is not equal to the center of the axis.
Is that a wished behavior, please?
Example: For an y_axis = [1..100], the awaited center position would be at
10 and not at 50.5. The center position for the logarithmic mapping
should be calculated as (log(min(y_axis))+log(max(y_axis)))/2, IMHO.
Kind regards,
Message 1 of 15
(4,745 Views)
which version of LabVIEW do you use?
Richard
Message 2 of 15
(4,706 Views)
I am using LV 2013.01f please
Message 3 of 15
(4,695 Views)
You are right, LabVIEW chooses this form (min(y_axis)+max(y_axis))/2).
You can go to "idea exchange".
Link:
http://forums.ni.com/t5/ideas/v2/ideaexchangepage/blog-id/labviewideas
here you can see how many people like your idea.
Perhaps it will be considered in the next version of LabVIEW.
Message 4 of 15
(4,685 Views)
Richard,
Please check with R&D to see if they consider this a bug. While it is the built-in behavior, it clearly is meaningless, if not wrong, for the logarithmic mapping option.  If they classify it as a bug, then it does not need to go to the idea exchange.
Lynn
Message 5 of 15
(4,673 Views)
Accepted by ghighuphu
Lynn,
it is definitly no bug. You can make a feature request.
I cannot escalate this case. LabVIEW wants this behaviour.
Perhaps it is possible to programm a work around with a property node.
Richard
Message 6 of 15
(4,661 Views)
Dear Richard, dear Lynn
thank you for thinking about the issue.
What do you mean by "LabVIEW wants this behavior"?
Working with a property node is not really a useful workaround: the cursor is going to be updated only when the VI is running. I am working with the cursor only when debugging, that means the VI is mostly stopped, o running step-by-step.
OK, I'll post it as a feature request.
Cheers,
Message 7 of 15
(4,652 Views)
Correction: the center on a log-axis is calculated differently:
y_visualCenter = 10^(log(min(y_axis))+log(max(y_axis)))/2
Message 8 of 15
(4,644 Views)
"LabVIEW wants this behaviour" means that the developer of NI programmed this function like this.
Sorry for my imprecise answer.
Message 10 of 15
(4,634 Views)
