09-19-2006 11:34 AM
09-19-2006 11:57 AM
Spectral measurements can be configured to show the output in linear values. When I do that and get the magnitude (peak), the values match. If I reconfigure it to result in dBs, it is correctly calculated. This is with a square wave input so that I know what to expect.
@mfitzsimons wrote:Does the Express VI, Spectral Measurements and the Extract Multiple Tone Information VI return the same data? The express VI displays the information in dB and the Extract Multiple Tone Information VI returns the amplitude in volts. The issue is that the amplitude don't seem to match. I am using 20log(volts) to convert to dB. The chart shows about -14 dB and the Extract Multiple Tone Information VI returns -27 dB (volts convert to dB).Any help is appreciated,
09-19-2006 12:33 PM
See attached VI in LabVIEW 8.0 to see what I am talking about.
First tone is at 298.9 Hz at 486.792 milliVolts
20 log(.486792) = -6.253 dB
But Chart is showing about -18 dB
What is the difference????
09-19-2006 12:34 PM
Bob,
I gave you 5 stars for the effort! Simulated data shows same issue.
Matt
09-19-2006 12:58 PM
09-20-2006 08:24 AM
09-20-2006 08:27 AM
09-20-2006 04:15 PM
09-20-2006 04:33 PM
