FPGA: IO Node
Under my FPGA target, I have a 9485 module.  I have all the 8 channels in my project, and I have a channel called "CH7:0".  What is that?  I assume I can select anyone of the channl with that?  How do I use it?
Kudos and Accepted as Solution are welcome!
(2,254 Views)
Accepted by jyang72211
This is the U8 integer that you want to write for all the channels from bit 0 to 7 at the same time. For example, to turn all bits on, you have to write 255 which corresponds to FF hex and 1111 1111 binary.
(2,246 Views)
ahhhh.  That didn't cross my mind for some reason.  A pretty good feature.  Thanks!
(2,233 Views)
