FPGA and measuring digital signals
Hi, I have a question about PXI-7831R and using ports.
In my configuration 6connectors with ports. Each of this ports has 8lines. I want to select only one of the lines. The example in the attachement
I made by my self but, I only can compile it with 80MHz. Is there any other way to do it more efficient? I mean with less functions, but the same functionality?
Thanks Marco
(2,481 Views)
Marco,
first of all 80 MHz is a quite good value which will be hard to beat but still there is a lot of room for improvement in your vi:
  • Avoid automatic datatype coercion (e. g. change the datatype for the "8" constant to U8)
  • Don't use front panel controls within a loop.
  • Avoid array operations. Either access the digital channels directly by line rather than by port or use your logical operations directly on the integer values (shift operations, bitwise AND, OR and so on)
  • Use single cycle loops and pipelining
There are several more things that can be optimized. Please refer to this tutorial for more information
Jochen Klier
National Instruments Germany
(2,464 Views)
