10-22-2014 12:38 PM
I will do my best to describe the issue I have been seeing. Note, I have tried quite a few other posts that sort of touch on my issues but they never seem to have a final solution.
Background -
I have 3 VIs:
VI 1) opens/runs the FPGA bitfile reference and stores the reference to a file global so that I can call the reference from other VIs. I need to do this as opposed to opening a new reference because I am using the FPGA for digital communication and it adds around 100 ms to to open a new reference every time I need to read/write to FPGA target from host (100 ms is a long time in digital world!). Some people use Shift Registers. I am ultimately calling all my FPGA host VIs from TestStand to run an automated test so it was easier to break up my open/close/read/write functions.
VI 2) calls the file global reference for FPGA then passes it to a read/write node to change parameters for the target then passes the output reference from the read/write node back to the file global reference
VI 3) calls close FPGA reference and the function is passed the file global reference.
Issue -
I don't understand why this method works just fine when either I am running from TestStand with station options set for developmental mode (not run-time) or when I have one VI opened that calls these 3 VIs individually in a sequential order but DOES NOT work when I try to run these VIs individually (Run VI 1 - open->write ref to file global reference -> Run VI 2 - read file global reference ->read/write control function ->receive error -63195) or when I run them in the same TestStand sequence but set with station options for run-time. Maybe I need to change TestStand sequence to load all modules upon startup?
Why does the reference get lost when switching between developmental and run-time and why can't labview file global keep the reference stored? Is there a work around?
10-23-2014 04:44 PM
Hi there,
Could you clarify for me the situations where it is working and it is not? Here's what I understand from what you wrote:
Is this correct?
Could you describe the specifics of the text from the error -63195 that you are seeing? A screenshot would be nice.
What versions of TestStand and LabVIEW do you have installed? 32 or 64bit? What about RIO drivers and any other drivers/modules?
Have you monitored the value of the file global while running the VIs? Particularly for situations 3 and 4?
10-24-2014 04:23 PM
Should have included this in the first post...hope it clears up some of the confusion.
WHEN RUNNING FROM LABVIEW ONLY:
Photo 1 works just fine….
Photo 2 (where I run DTL_OPEN.vi, standalone, first then I run DTL_READ.vi, standalone) does not work…
It is like the FPGA completely stops when there is not a thread running directly calling it…
WHEN RUNNING FROM TESTSTAND ONLY:
The TestStand issue is even weirder…I just figured out the repeatable trend when running in “run-time”. Apparently, I call the DTL_OPEN.vi (it works), then I call the first DTL_READ.vi (it works), then I call the second DTL_READ.vi (it aborts with “Error: LabVIEW: VI was aborted. [Error Code: -18002. LabVIEW reported an error…”). After the VI aborts, the sequence is terminated. I rerun the sequence and the second time I run the sequence, the first DTL_READ.vi no longer works. The only way to make the first DTL_READ.vi work again is to File->unload all modules. Rinse and Repeat problem…
Of course when I am running the test sequence in “developmental” mode in TestStand, I get no errors and FPGA works like a champ…calling DTL_OPEN.vi, then making multiple successive calls to DTL_READ.vi with no problem…This, to me, would be like running the VIs individually in LABVIEW ONLY (which did NOT work)…
Obviously I am missing something big on how the FPGA references is being stored/passed and how the FPGA is behaving after calling the "OPEN FPGA VI REFERENCE" node (I do have it checked to run the FPGA VI when opening the reference). I had thought that the FPGA would continue to run the compiled code until it is reset and the reference closed.
10-27-2014 04:38 PM
Hmm... that Error -63198 that you are seeing may be resulting from too many reference handles being open that aren't closed. Try doing this.
In your Open.vi :
Then in your Read.vi :
In your Close.vi :
You are right in that the FPGA VI continues to run until it is reset. I think our problem may lie within the references being passed around.
10-27-2014 05:19 PM - edited 10-27-2014 05:30 PM
I believe what you are suggesting would work but the problem is that I am trying to avoid the extra open/close calls since they add time to my execution. Again, I am using the FPGA for digital communication (calling read/write nodes thousands of times). The 100 ms to call open really does add up...this was what I did not want. I still don't see why it works in development mode in teststand and not in run-time.
Thanks for your help, I am still a little confused. I know it is the reference that is the problem and calling it from a global VI is just not working in run-time. I believe that is where the problem is, in getting the FPGA VI reference from the Global.VI.
When running in TestStand, I proved out that the VI aborts after trying to grab the FPGA reference from the Global.vi (the error occurs before the read/write node). I just don't understand why.
10-28-2014 03:07 PM
Hmm I see. Is there any reason that you are calling your read/write VI a bunch of times instead of using a for loop? I'll look into if there's any other way to transfer the FPGA reference that wouldn't have the same problems as a global variable.
11-04-2014 04:23 PM
I am not sure what you mean about only calling them from a for-loop instead of a bunch of times. I call the host VIs from TestStand sequence steps executed one at a time (no multiple threads). I sometimes will have the Host VI calls in a for-loop in my TestStand sequence but not always.
Any ideas on the problem with the gobal variable or a work around?
Thanks again for all of your help so far.
11-06-2014 11:14 AM - edited 11-06-2014 11:14 AM
Rather than using a global variable, you might have better luck using a local variable (at least in TestStand). TestStand has a variable type for passing references (LabVIEWIOControl) that is intended for this sort of application. Take a look at this KnowledgeBase Article (Calling LabVIEW FPGA VIs From TestStand), it has an example attached that shows how you can open a reference and pass it between steps.
11-07-2014 01:49 PM
Finally found a solution. I don't understand why it is required when reading from the FPGA and not when writing (actually I don't fully understand why it worked at all) but I ended up changing the Step properties in my TestStand sequence for the step calling my DTL_READ.vi to be Properties->Run Options->Unload Option->"Unload after step executes". This seemed to do the trick to get my TestStand test sequence to work in Run-Time engine.
I still don't understand why this was not required when running the same sequence in developmental mode and why it is not required when I call my DTL_WRITE.vi.
Both the DTL_READ.vi and DTL_WRITE.vi pass the labveiw global.vi parameter "FPGA VI reference" to a read/write node. I don't know if the root of the problem is in my LabView FPGA host VI or in TestStand...
Thanks for all of you guys' suggestions! I am happy I have it working but I am still confused by the solution.
