FPGA
I want to run a simple math VI on an FPGA target(cRIO 9068).  VI compiled sucessfully and the bit file is generated. But when I run the VI on FPGA target, it shows the error "LabVIEW FPGA called another software component, and that component returned the following error:Error -63034 occurred at niFpgaOpenAndRun_cRIO-9068.vi
Please suggest a solutin
Shaji
(3,289 Views)
show your VI and how you call it to get help...
(3,266 Views)
Project files attached
(3,252 Views)
Created the bit file and run the VI using run button to run it on FPGA
(3,248 Views)
That is almost completely useless.  The project file does not contain any code.  Please put your entire project (or at least the relevant parts) in a zip file and post that.
GCentral
(3,238 Views)
Please see the project zip. sorry for the mistake
(3,231 Views)
How are you running this FPGA?  Where is the RT code that is calling it?
GCentral
(3,214 Views)
