Failed to create installer though it creates executable
Maybe someone has an idea on this problem....
A few months ago I did an installer with no problem but after I changed some details and wanted to
do it from the beginning it does not "allow" me to. For two different applications.
Thank you!
(2,918 Views)
Hi Eleftherios,
could you provide some more information? What OS are you using, which LabView version, on which version were the projects originally created. And what did you change since the last compile?
Some possible solutions you could try:
1. Mass Compile on your Project error 1:
http://digital.ni.com/public.nsf/allkb/229402206118211186256752005C1E40?OpenDocument
2. Check out this knowledgebase error -12:
 http://digital.ni.com/public.nsf/allkb/afc375154efbd6ae8625760b005fb723
(2,899 Views)
I am sorry I forgot to mention i use windows XP and LabVIEW2010, they were developed from me and I have not changed anything important since last time.
Thank you for the links you gave me. I shall read them this afternoon when I find the time. 🙂
(2,894 Views)
Try enabling debugging for your application. There is a bug out there (forget the CAR #) which results in builds requiring the build to enable debugging for it to be successful.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,881 Views)
Thank you for your answer,
I enabled debuging on the executable it is builded just fine but then when i try to build the installer it pauses to the part where i have attached( build error) for 10 minutes and then i get the message i have also attached( build errors).
I include the run-time engine in my installer.
Any ideas please?
(2,862 Views)
Accepted by Eleftherios
Finally a colleague of mine discovered what was wrong:
"LabVIEW failed to build its installer due to what presumably was caused by permission settings on the remote storage used to store the project.
By switching to a local storage on the windows machine (C:\) the installer compiled as it should"
(2,846 Views)
