Flatten floating point on FPGA for multichannel DMA
We have a large FPGA application on a cRIO with 3 DMAs and are trying to transfer mutliple channels of data through a target-to-host DMA.  We have a large variety of types (U8 to floating point) to support but I can't seem to find a way to flatten (extract the bytes of) the floating point quantities to stuff into the DMA.  I don't want to use a second DMA.
Any tips?
thanks,
Steve
Message 1 of 17
(4,180 Views)
You should be able to build them into a cluster and pass the cluster through the DMA.
Message 2 of 17
(4,161 Views)
Hmm, doesn't look like DMA FIFOs allow cluster data types.
Even if they did, that probably wouldn't work for our situation.  We have multiple loops of different (and sometimes varying) rates writing different data types to the DMA so clusters don't fit well.
We're currently using cluster indicators, and they get flattened/unflatted by LabView to pass to the RT layer (as described here).   We're running out of gates and want a more robust design so we're switching to DMAs.  I wish I had access to the flattening code/node!
Steve
Message 3 of 17
(4,152 Views)
Message 4 of 17
(4,146 Views)
That page is very misleading.
FIFOs which are FPGA-FPGA (On the same card) can have custom controls, FPGA to host or host to FPGA cannot support custom controls.
That much I know.
Shane
Message 5 of 17
(4,143 Views)
Clusters are supported on target-scoped FIFOs, but not DMA FIFOs
From that page:  "Note  DMA and peer-to-peer FIFOs do not support custom data types."
I actually verified this in FPGA 2013 before responding to your first post ...
Thanks for replies, though.
Steve
Message 6 of 17
(4,140 Views)
Hmm, I didn't see the note.  It's right beside larger Bold text and the other text kind of steals the eye away.....
Message 7 of 17
(4,138 Views)
Can you use typecast to turn the datatype into an I64?
Message 8 of 17
(4,133 Views)
Don't want to convert to integer (changes the value).  I just want to take the 4 bytes in an SGL (or two bytes of a U16, etc.) and send them through the DMA as U8s.
Steve
Message 9 of 17
(4,123 Views)
No.  Typecast it to an integer.  Send through the DMA.  Typecast back to the original datatype on the other side.  It won't change the value.
Message 10 of 17
(4,119 Views)
