09-04-2012 04:35 AM
I am using labview 2010 SP1 and windows 7.In the front panel I am using the cluster controls.the controls using Application font 16.This cluster is a typedef cluster.cluster allingn ment and arrangemnet are fine in windows 7 and labview 201sp1.If i move my application to otherthan windows 7 or different labview version.The application font size is shrinking to 17 application font.So it is changing front panel controls allingnment.so it is affecting my applications asthetic look.Can any one give the solution for this problem.
09-04-2012 04:40 AM
09-04-2012 04:51 AM
hai danil i already aware oof this.I tried apllication font thatmeans messege box font as tahoma and ,size is 10.I tried this.This messge box font setting is working fine in same version of labview for same Operating system it is working.If I move different operating system or different version of labview it is not working and also I am using dynamic calling for this vi
09-04-2012 05:06 AM
See the thread discussing similar thing.
09-07-2012 12:24 AM
hai danil I am checking the program I will give reply after checking the program
09-07-2012 12:34 AM
Are you using typedef or strict typedef controls?. I guess strict typedef may fix the problem but not sure about how LabVIEW GUI changes depending on the OS.
09-07-2012 12:39 AM
No i am not using strict typedef because dynamically i am changing the value of the that control.so I cant use strictypedef
09-07-2012 12:50 AM
Unless you change the property of the Control you should not be having any problem in using Strict typedef.
09-07-2012 01:12 AM
ya but the controls are combo box array so every time i am give the string property values to combo box...so it is crating the problem.other than that I locked the cluster arrangement.I am using application 16 font.in difererent version of labview it is changing to application 17 font
09-07-2012 04:23 AM
