For Loop to Iterate with Larger Arrays
When two or more arrays are fed to a for loop, the loop always iterates with the smallest array size.
See the attached picture. For example, Array A with size of 2 and Array B with size of 4 are fed into a for loop; the loop only iterates for 2 cycles. How to let it iterate 4 cycles?
I know that I could predetermine the size of each array, and insert some empty elements to the smaller one to make both array equal sizes. But is there an easier way to let the loop to iterate with the larger array?
(3,375 Views)
You could use a while loop instead which would use the default data for the type after then last element.
(3,360 Views)
Perhaps if we knew what you really wanted to do, we could offer a more elegant solution.  (Surely you're not just taking the two arrays apart just to put them back together again.)
Bill
CLD
(Mid-Level minion.)
(3,351 Views)
For a for loop, no.
But the following hack should work.
mcduff
(3,345 Views)
Or you could just use a 2d array...
(3,329 Views)
Build Array will add the additional elements to the smaller array.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(3,314 Views)
First have a look at point 4 in my 11+ year old post (that was before the ideas exchange!). Then also have a look a this idea.
(3,305 Views)
