Front panel Video problem when using Tab
Hi to all ,
Has anyone have has this kind of video problem ? , i'm using tab with no prob , but at a moment
the video seems to double the infos on the screen ( see below ) The functionnality stay , but very difficult
to work
David
(354 Views)
I have no idea what means "using Tab", but it looks like Video Driver problem. Try to upgrade video driver to the latest version if not done yet. By the way - which LabVIEW version, OS version and graphic card you are using?
(350 Views)
Post that VI! I'm GUESSING that there is some strange splitter without visible elements or other Silly Things (tm) that we cannot see in a mere picture.
"Should be" isn't "Is" -Jay
(314 Views)
A truncated static picture of a front panel where we cannot see a tab or a video is not really suitable as input for troubleshooting.
What tools are used to display the video?
(308 Views)
Hello
I m using Windows 10 Prof Version 22H2 on a Vostro 5568 m i have downloaded the last drivers from Dell but the problem still present
I made a last test to explain the prob very stange , for ex when the prob occurs even if the VI is not running the bottom of my VI seems truncated
see the dark green color
if i use the vertical scroll bar , my VI seems to disapear even if the now invisible buttons are still active
 Never see this problem when using Labview , V2017
Have you an idea ..
Thanks in advance
(268 Views)
This is the VI
(267 Views)
No it's not
(253 Views)
