05-04-2023 12:46 PM
Hi all,
I am trying to make Modbus communication happen between cRIO and the flowmeter. I am trying to use Modbus create instance.vi but nothing appears on the VI in cRIO. Moreover, I cannot see any functions on the function palette on this VI unlike VI's in the host computer. Is there any way to see functions on the function palette in cRIO VI. Thank you.
05-04-2023 01:18 PM
Which Modbus library you are using? Some libraries are only supported on certain targets.
Modbus Communication Using LabVIEW or LabVIEW Real-Time Module
05-04-2023 01:47 PM
I believe I use the Modbus not Modbus Library.(The blue box in the given link.) I cannot see any other things on the function palette other than Modbus function.
05-04-2023 02:07 PM
Can you provide a screenshot of this?
I think you might have to run a repair on your LabVIEW Real-Time Module. Modbus Palette Missing in LabVIEW
05-04-2023 03:10 PM
The link is not related. What I meant is there is nothing on the function palette when I created a new vi on the cRIO. I can use Modbus on my host computer but not on cRIO.
05-05-2023 12:59 PM
You attached a picture of Project Window but you are describing an issue with the function palette for block diagram. How is that related?
