General questions about wait function within a sub-loop
I had a general question about the "wait" function. If I have a case structure or while loop within another while loop, how can you make the "wait" only apply to the sub-loop, rather than making the entire loop wait? I know there is probably a super easy solution, but I can not figure it out. I have been using an "elapsed time" function to solve this problem.
Message 1 of 12
(1,091 Views)
I would not recommend using loops within loops. Use a state machine instead. You can place the wait function inside a certain case with the state machine.
Control Lead | Intelline Inc
Message 2 of 12
(1,065 Views)
You can't. You're using the wrong design. What are you trying to do?
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 12
(1,053 Views)
You can use that to "wait for" (check if time is passed) a time (aka polling), but not to "wait" (stall execution).
Structures (well, more accurately structure frames) will wait until everything executing in it is done. Always...
Message 4 of 12
(1,041 Views)
Remember the Three Laws of Data Flow.  The Second Law says a structure runs until everything inside it has run.  So the Wait in the sub-loop means that the sub-loop "waits" as instructed.  Anything that contains this sub-loop also has to wait, as it is also obeying the same Second Law, and cannot exit until its inner loop (with the Wait function) finishes.
Note that any other structure that does not "depend" on the inner "Loop With a Wait" is free to run (in parallel) as a result of the Third Law, but that's another lesson.
Message 5 of 12
(1,014 Views)
Sorry, but no!
It's nitpicky, but formally not correct. A structure frame runs until everything inside it has run!
Spoiler
Flat sequences are structures too...
Message 6 of 12
(976 Views)
Until I read the Spoiler, I didn't realize the subtlety of your "nitpicking".  You are, of course, correct, though I (personally) view Frame Sequences as "sequential structures" (Frames) (my bad!), and something to be avoided (except for FPGA code).
Message 7 of 12
(963 Views)
I agree, but they're still structures!
In general there's very little you can say about anything in LabVIEW without any reservation.
Message 8 of 12
(950 Views)
If you see a Flat sequence as an array of structures it still holds. 🙂
Qestit Systems
Message 9 of 12
(945 Views)
Sure.
To be fair, even in LV's class structure a flat sequence isn't a structure (or even a node, until you ask for nodes, and they are still returned in an array of nodes 😲).
The norm is to consider a flat sequence as a (single) structure.
Message 10 of 12
(919 Views)
