06-11-2023 09:15 AM
this is the latest
06-11-2023 11:28 AM
01155990@pw.edu.pl wrote:
this is the latest
Did you mean to attach something?
06-12-2023 08:12 AM
Thanks for sharing for LV 2020. I noticed that the values generated never changed no matter the input.
I changed the routing of the cluster to bundle AFTER the case structure.
Before the change, the case structure had no effect on the result, showing always the same result.
It changes now, but the height needs some adjustment.
Good luck !
06-13-2023 04:50 AM
Thank you very much for your help. May I ask if you can upload the file here so I can have a better view at it and understand it fully. Thank you again
06-13-2023 07:59 AM
I just rerouted the input of the cluster, the unbundle receives AFTER the case.
06-13-2023 09:22 AM - edited 06-13-2023 09:30 AM
You remind me of one of my former cow-orkers. He's a hack. He puts practically no thought into anything. And of course, like you, he puts zero effort into producing clean code.
I threw most of your mess away and came up with this.
