Gerber files
Message 11 of 15
(1,253 Views)
Hi Mathan,
Thank you for your reply. I read the article and it is about exporting gerber files from Ultiboard. What I want to do is to import this in LabVIEW and do several instructions (assembly, inspection, or motor movement) using the coordinates in a gerber file.
Message 12 of 15
(1,251 Views)
Hey,
This is exactly the same programm i need to make using labview.
My experience with labview is as good as none... but writing the programm in labview is a must.
I was wondering if anyone is still working on this project.
If so, please contact me, maybe we can use each others experience and research.
There was a previouse project group at our school who made the beginning part of the project.
One person already wrote a code which extracts the usefull data from the Gerber file (X and Y coordinated and surface area of the pads). I will attach this file in this post.
The problem is: it is not working...
I hope to see a response from anyone!
Message 13 of 15
(1,217 Views)
JanTromp,
It looks like the original posters haven't come back to this thread since 2013, it might be best to try opening a new thread of your own to get some attention to your question. I'm not too familiar with this gerber files but I know the community over at the Multisim/Ultiboard forums have a bit of experience, it is possible that some of them have worked with gerber files inside of LabVIEW!
That forum can be found over at http://forums.ni.com/t5/Multisim-and-Ultiboard/bd-p/370
Best of luck,
Brandon
Applications Engineering
Message 14 of 15
(1,184 Views)
Tnank you so much
Message 15 of 15
(561 Views)
